Marantz 6002 amp
stevee1966
208
6
18,795
Just noticed on spec in What Hi-Fi that the Marantz amp does not have a 'preamp out'. Does this mean that i cannot connect a turntable ? Also the spec says no 'MM Phono' but Richer Sounds spec says it does have 'MM Phono' What exactly does this do, and does the amp have this functionality ? cheers
Andrew Everard
1,878
The preamp out lets it connect to an external power amplifier, for more power or biamping. But it doesn't have one.
The MM Phono is a moving magnet phono stage, which lets you connect a turntable. It has one of these.
For confirmation see here.
(Four minutes - not bad, huh?)
stevee1966
208
6
18,795
[quote user="Andrew Everard"]
[/quote]
but a massive 58 minutes to thank you.
