How do you resize pictures to fit onto the forum? I know you want them 400x400. When you see a picture size on the properties tab, and it states 500x350 pixels, which one is the width and which one the height?
To resize them, when you post a picture the 'insert image' tab lists the current dimensions of the image pasted into the link box. Just reduce these to fit. (Try and keep the ratio the same.)
idc:How do you resize pictures to fit onto the forum? I know you want them 400x400. When you see a picture size on the properties tab, and it states 500x350 pixels, which one is the width and which one the height?
Reduced from 1024x768 pixels. Thanks Messiah and Andrew. By the way, I did not have to copy and paste the dimensions, they just appeared in the size boxes when I clicked into them.
