hi I have a sony kdl32d3000 tv will
i get eny improvement by upgraiding the mains lead for a better picture or sound quality thanks mike
John Duncan
2,033
27
19,720
I say yes, others will say no. Most dealers will let you try one at home to find out, since it's not like you can damage them. Does your telly have a kettle lead input though - I'd have expected it to be a wall-wart power supply?
VoodooDoctor
81
I tried a fancy mains lead on my previous Sony LCD. Couldn't really see a difference so returned it.
Try and get an audition before you part with your cash is my suggestion.
How can a different mains lead help a TV which is digital and uses a switched mode power supply (which converts AC to DC back to AC and finally into DC again). Even if you buy into the debate about higher quality mains leads providing a "cleaner" power path, then it can still only provide this higher quality path between the TV and the wall socket. All the wiring throughout your house, from the wall socket to back to the consumer unit is almost certainly standard solid core twin and earth cable which costs less than £1 per meter, so the power "quality" is already limited by that wiring, not to mention the cables and power transmission equipment between your house, the national grid, and the power stations.
If you could do a double blind test comparing standard power cable with the expensive specialist ones in a normal home/office, then the results would be pretty much random.
Save your money for better interconnect cables, better source equipment, beer etc.
