LOUDSPEAKERS MONITOR AUDIO BR1
I have buy a Monitor Audio BR1.
I Need to now, the best stereo amplifier that you recommend to works
with Monitor Audio BR1 ???
Hi cardoso
What source component/s do you use?
What do you and anyone else who is also going to use the system generally listen to?
Is there anything in particular you would like the amplifier to have (tone controls, remote control, headphone socket, mp3 input, phono stage etc.)?
Will the speakers be stand, shelf or wall mounted?
Your room size?
Is the room lightly or heavily firnished?
Your listening distance?
Your general listening level?
Any specific power requirement?
The speaker cables?
What kind of presentation are you looking for the amplifier and the system as a whole to reproduce?
Your budget?
All the best
Rick @ Musicraft
ASK THE COMMUNITY
