- Aug 10, 2019
- 2,556
- 4
- 0
That loudspeakers recommend to me for Pre Xpd's good profit Qx/2x X-Power?... Proac, PMC, Spendor, Vienna... Thank you.
Hi mike43mike43 said:That loudspeakers recommend to me for Pre Xpd's good profit Qx/2x X-Power?... Proac, PMC, Spendor, Vienna... Thank you.
If I have the electronics and buy it without listening to her.MUSICRAFT said:Hi mike43mike43 said:That loudspeakers recommend to me for Pre Xpd's good profit Qx/2x X-Power?... Proac, PMC, Spendor, Vienna... Thank you.
I hope you will not mind but just to get a clearer picture of your circumstances/requirements -
Have already got these Cyrus electronics? If so, did you listen to them before yoiu bought them? If so, what source component/s and speakers were used?
What speakers do you currently use?
What source component/s will you use?
What do you and anyone else who is also likely to use the system generally listen to?
The size of your room?
Ceiling height?
Room walls (brick, concrete etc.)?
Room positioning of speakers (in relation to walls, corners, will there be anything between the speakers such as a chimney breast, cabinet, windows etc.)?
Distance between the speakers?
Your listening distance?
Will anything be in the way of the speakers?
You general listening level?
Is your preference for bookshelf speakers , floorstanding or either?
Is your room lighltly or heavily firnished?
The room floor (concrete, carpeted, wooden etc.)?
The speaker cables?
Will you use the power amps in stereo (to bi-amp) or as mono's?
Will you also be adding PSX-R's in due course?
Your overall budget?
All the best
Rick @ Musicraft
So articulate and easy to understand, I contribute.mike43 said:Do they cost the information that I contribute?.Thanks.
Hi mike43mike43 said:Thanks for your reply Musicraft.Regards from Spain.
Thank you for your advice Gaz19. I seek for something good to take advantage of the equipment cyrus and also it to connect to an Onkyo TX-NR5007 .... for cinema and music rock, orchestral.Gaz19 said:Trust me, with Cyrus you have to audition so that you dont end up with bright sound that gets on your nerves. People say Spendor are boring but they when you put them with Cyrus they kind of balance each other out. I have monitor audio gs10 and they are amazing but too bright in the high treble...
