LOTTO Speakers ?
As the title suggests Andrew...... So are they as good as they look and do they warrant the kings ransom ?
Andrew Everard
1,878
It was quite a while ago, but I remember they were very impressive.
Similar note... I have heard a pair of Gryphon Poseidons. They're a dual box 2 meter high active floorstander with about 17 or so drive units per channel. They were incredibly impressive, although I don't think they warranted the 170,000 euro (or similar) price tag.
chebby
1,251
24
19,195
noogle said:
Presumably they stay stuck to the floor if your room tips upside-down? :)
So they would be 'Lotto' but not rollover speakers?
Of course, if your room did tip upside-down, there would probably be more to worry about than what your speakers are doing!
Ok i,ll go with it ! Would the sound WAVES plum new depths in the bass dept ?
lindsayt
16
MattSPL said:
If you google them, you'll find some information.
10hz bass response 8)
When I googled them I couldn't find any technical specifications, nor any frequency response measurements.
Andrew Everard said:
Much smaller than the B&W Nautili. Around a metre or so tall, IIRC.
Not really 'much' smaller, the Nautilus are only 1.2m tall.
Re: the 10hz comment. That was measured at -6db. Still incredibly impressive though, many/most subs cant even match that!
Andrew Everard
1,878
In which case, the Forgings speakers may be smaller than I recall: I remember they were considerably smaller than the B&Ws.
But to get back on topic, I'd possibly have a pair of these:
