Looking to buy a used turntable.
apking
But there is so much choice!
The last turntable i owned was a michell syncro, not my favourite tbh.
I have a budget of around £500 and am looking initially to use it with ATC50 SCM monitors.(I already have these)
What do people think would be a good starting point with this budget available.
I feel quite lost with all the products out there that are available!
:help:
apking
I am open to anything in that price bracket.
There is however plenty of choice out there. I dont like buying without good advice.
I gererally find that hard to get from retailers..
stevebrock is quite right but you may be looking at £550 for one fitted with a cartridge.
Do you already have a cartridge?
I know quite a few turntables these days come without a cover of any sort, is this a no no for you?
Look out for a second hand Roksan Radius 5 if you can, they are particularly good but again they do not have a cover.
I would stear clear of Technics SL1200 direct drives and the like.
stevebrock
183
If you are competent fitting a cart then a used Roksan is possible, however I would avoid buying one off the bay unless you can collect it! BBB had a nightmare buying one.
Not sure what the RP3 without cart retails at but Alears is correct its £550 with an Elys2 and this is not a shabby deck, however I would put a different cart on, maybe Ortofon Red?
B
BIGBERNARDBRESSLAW
But it's come good in the end.
Are you saying I'm useless at fitting cartridges Steve? :rofl:
stevebrock
183
if i recall, it wasnt you fitting the cart, but the strange cartridge fitting? also the damage?
I am quite confident you know how to fit a cart!
oh yeah not forgetting the Clearaudio incident - my point was the buying on ebay bit :)
drummerman
540
ifor said:
For £500 you cab get some amazing 2nd hand kit.
Agree.
New the only choices are from Rega and Project, neither to shabby it has to be said but for £500 I'd be also looking s/h.
Having said that, you almost certainly have to budget in a new cartridge/stylus that way.
regards
Jim-W
There's a Revolver tuntable on ebay for £149.
Not as beautiful as the Thorens but a very decent s/h buy. Much better sound quality than a new budget deck imo. Replace the AR cart with an MP110 or even an AT95 and this would sound pretty damn good. Jelco rebranded tonearm is a feature;I think they fetch about £300 these days. Worth a look for the price.
