omnibeard said:
CJSF said:
I get excelent SQ on the £5 per month service. I dont need all the knobs and whistles and aps that you get for £10. No need for ipods and the like.
CJSF
Not aware of the knobs/bells and whistles - I just pay to not get the adverts.
CJSF - how much are you loving your Croft amp? It was the main reason I bought my Monopulse speakers, having listened to them at a friend's house on the end of (probably/possibly) the same amp. Will def buy some Croft stuff at some point. Love that homemade British stuff - same reason I bought my Beresford DAC. Which I love.
Hi Omnibeard, knobs and whistles; are all the various things that can be done like use on iphone, various aps etc. The £5 unlimited version just plays music with no ads, they say the bit rate is less . . . ? I get excellent sound quality IMHO.
My limited, basic system has been built around my Croft amp, I have built the system with Croft as its heart, cables are low cost, TT set up is tuned to my ear, new bearing and sub platter and I use an expensive cartridge, all a no,no if you read the threads?? Every change I have made, the Croft has stepped up to the plate and given a perfect insight into what was happening with that change, good and bad.
So yes, I love my croft, it is the best of both worlds as a hybrid, delicate signal handling on the valve based line in/phono side and the grunt of mosfets on the power side. Glen has so many years of personal hands on developments, he is passionate about music and hifi. This passion and years of knowhow is evident as one sits and listens. I have no desire to change anything in my system, I am very content with my simple system, cheap cables and low cost TT. The expensive bits, speakers and cartridge fit in perfectly. 'The sum of the parts exceed the whole' as they say . . .
I am totally unaware of a system signature, which means, what I hear is what is recorded. Now, whether that is in truth true, matters not? The integration of the parts means I just dont hear it, which does matter to me.
"I have a valve based system which does not sound like a valve system . . . "
CJSF
