Looking for DAC
tansriloi
14
Hello,
Looking at a Dac for my Small System. Would love to run a coaxial digital cable from CD player to my Bose sound dock which only accept 3.5mm. Any recommendations. I have got £100- £200 budget. Seen many cheap DAC on eBay but afraid it's not good sound quality. Will any of these Wolfson or Burr Brown chip makes any difference?
davedotco
What are you trying to achieve?
Your CD player will have an adequate dac built in, difficuly to see what advantage a separate dac will give you. Improvement in sound quality will be minimal, do you need extra functionality?
Native_bon
180
Well, depends. May be at that price point it may not make much difference. My M-DAC adds a little more drama to the sound from my Oppo105eu
Native_bon
180
tansriloi said:
Hello,
It would help if you can give a little more info..
Andrewjvt
99
Once you go dac you dont go back.
If you want to rip cds onto your hd then id get one.
But if its just to play cds then not really an improvement unkess tou have a very poor sorce.
For £200 budget id consider a dac magic
tansriloi
14
My dock only takes in 3.5mm so I need a converter from CD player output to my Dock. At the back of my CD player I have got an optical and coaxial output. Analogue been used already.
davedotco
For what?
If you can only use the digital outputs to connect to your sound dock then a dac is necessary. I see no reason to spend more than about £30 on this.
http://www.miccastore.com/images/gallery/51/d03k-alone-1280.jpg
ID.
207
davedotco said:
For what?
a great little DAC. More than enough for your needs. I use one for my tv into a preamp. There isn't a big difference between the FiiO and my Icon HDP.
