SlickenSmooth:I'm looking at the Cyrus 6 SE but heard a lot of bad stories about their consistency and build quality.
Build quality does leave something to be desired. You would be right to expect higher quality of finish and production for the price. Though it is the design of the slot bezel, amongst several other issues, that have seriously let down these SE CD players from Cyrus. You've only to look at the image of an 8se on page 32 of the November 2008 issue of What Hi-Fi to see a case in point. Turn the page sideways to look "along" the slot. The lower edge of the bezel is raised well into the slot space at its central point. That deformed slot-bezel is likely to cause damage to the playing surface of your precious CD's. Look at the newly designed (smiling) slot bezel with its downwardly curved lower edge to give more clearance, tell you anything?
Why the What Hi-Fi review did not make mention of this faulty bezel can only be known to them. Though it raises fundamental questions about their reviews. Can they be trusted to tell you the bad points aswell as the good? How many other products have they reviewed that have had faults like this that they have failed to mention? Certainly my trust in What Hi-Fi reviews has taken a downturn.
Back to that slot bezel. I've had units where the disc has jammed on the top edge of the slot upon ejection, just because of the extra thickness of a label attached to the CD! And CD's without a label have scraped & rubbed on the top edge, this due to faulty plastic moulding and excess plastic on the top edge of the bezel! Shouldn't happen.
It is my opinion that the SE players were not sale ready with this poor design, though perhaps they are at last maturing into a useable and SALEABLE product.
Cyrus have known about these issues for a LONG while and only now are they being addressed. I don't for one minute believe that my own emails to Cyrus about this poor design have had any influence, because Cyrus must have known this was poor design from the off. The new design LOOKS nicer, but it remains to be seen if it will perform any better in use.
There have also been issues with the display giving incorrect readings, failures to load a CD at all (every disc ejected with "Disc error"), CD/CD-R playabilty, and even problems with the paint finish of the magnesium case. The last 8se unit they sent me showed such a massive variance in silver finish to my other five Quartz units that I was utterly sure it must be the OLD silver finish. It was so much lighter in shade. However, it became apparent that this was in fact Quartz Silver and it was left to my dealer to make me aware that Cyrus were "enjoying" a batch of cases that turned out to be MUCH lighter than they should have been. Again, I believe you can see this variation of silver colour in some of the recent reviews of various Cyrus units in What Hi-Fi. I took a photograph to show this variance of colour.
CD-R:
Cyrus made a statement to me, and I quote "The SE platform does not have a problem with CD-R".
I don't believe this to be true. In my opinion the SE platform does have problems with certain CD-R types, of that I am absolutely convinced. Along with the cosmetic changes there is mention of another software upgrade which may address these disc playabilty issues further?
I've had 5 8se units, every one of which had various faults and fell well short of my expectations of a CD player at this price point.
