Looking for a fully function Radio with Aerial socket.
Omits
But i can't find one in the UK. The only option seems to be a car radio (not preferred) but most of these use a remote via an App on mobile. i want a separate controller.
Advice appreciated. thanks.
Gray
A 'fully functioning radio'?
That suggests something with its own built-in speaker(s) - unlike a car radio.
If you need to add speakers anyway, then why not add a small, cheap amp (or powered speakers) to a standard tuner - every one of which has an aerial socket?
Omits
Sadly enough I recently got rid of some powered speakers. Still looking for the portable option really.
Omits
Not sure 'Plasma'. Spare room radio, rem control, aerial skt for best reception (NOT a telescopic - useless IMO), in-speakers. BT for headphone listening would be nice.
DCarmi
415
304
5,270
The Roberts Stream 94i, the aerial panel unscrews to reveal an F connector.
I think the Pure Evoke F3 uses an F Connector and probably easier to access, than the Roberts.
Best to check rather than take my word for it. Both are DAB and Wifi devices.
Lost of mini systems have F connectors. Another alternative is to go with a smart speaker and internet radio, as suggested above.
Reactions: Tinman1952 and Gray
