Has anyone connected their Musical Fidelity or any other DAC to an expensive power supply such as the Little Pinkie? Was the difference any good? Is it worth the £100
There was a post before about these PSUs here; http://community.whathifi.com/forums/t/228268.aspx . I put in an order for the RA one, but cancelled after they took an age and I wanted an extra length of cable. I then found out about Rock Grotto, but got my amp modded instead. All I can say is that the Little Pinky gets rave reviews elsewhere and I will get one, once my new amp is out of warranty. If MF find out what you have been up to they will not fix any problems. But I have no doubt that Rock Grotto workmanship is excellent and Mike Grierson will sort out any problems. I will eventually get one.
My MF PSUs get very hot. The smaller one for the X-CANS looks and feels very cheap and the connector to the amp is a poor fit. That does suggest an upgrade would be beneficial.
