Linn Kaber L/S BiWired With Linn K400
georges
Hi.
New To The Forum Any Suggestions Please Regarding Change Of Speaker Cable? Full Linn System With LP12 No Mods Carried
Out In last Two Years. Loss Of Bottom End. Have Not Checked Out Lp12 But Dont Think It Would Be The Cause Of The Problem.
"AH" Maby You Will Say There lies His Problem
Georges
if nothings changed could it be the cartridge is worn out?
I've not seen the Kaber's but do the cones have screws you can tighten? I've been told you should check them every so often if so.
georges
Hi.
Just Got My Self A SamSung LCD Full HD Series 5 32" Connected To Sky Box, Also Feeding In Cable Signal Both Analogue
Have Not Upgraded To Sky HD As Yet. Signal Quality Is Very Poor, No Amount Of Tweaking The Colour Etc.... Makes Any
Emprovement, In Fact Picture Quality Is Becoming So Poor That I Could Give The "Lot" A Miss. DVD Is Denon Upscaled To1080p
HDMI Looks The Best, Just About!!
No Fault Exists On The LCD. Looks Like Will Have To Go The Way Of A Set Up DVD Think This Set Only Likes HD Signals.
Using All Good Interconnects.
Any Advice Appreciated
Thanks.
Georges
