Lengthening speaker cable
Greetings ~ I have speaker wire embedded in my walls and I need to lenghten it
Any ideas on a good way of joining wires?
fatboyslimfast
158
Best way would be to push some heat-shrink sleeving along the cable somewhere, solder the two together, and then put the heat-shrink over the join, and shrink using a hairdryer. The heat-shrink will then act as an insulator. I think Maplin do the stuff...
Depending on what guage your cable is, you might need a hefty soldering gun, rather than an iron intended for electronics use...
You can alsoget some specific banana type plugs that do the job. You connect your cable to a plug, the extra bit to another plug, unscrew part of one plu and it makes a socket so you can join the two together. There is a name for tham but I can't remember what it is.
Whats wrong with good old chocolate blocks. The best way to fit them is to twist the 2 pieces of cable together and then put them in the same end of the block, you then have 2 screws holding both pieces of cable in place.. Just get the appropriate size to match the cable. Maybe not thet pretty but easy enought to hide.
Thanks guys ~ I see that I have a few options.
I am currently using chocolate blocks but didn't think of twisting the wire together first and then screwing them in.
I'll have a pop at that and see if it makes any difference.
best use of block. get the wires under both screws aswell. it can be a bit more tidy to feed a wire in each end, but see that they pass each other and get both screws down on them. not to tight with the screws to, its an electrical connector, not a wire cutter :)
maplin will sell them in gold for car audio. Only cost a leg lol
