That's a difficult question to answer without knowing your requirements. If you only ever plan to use it as a laptop using its own screen then it doesn't matter what sockets it's got. If you intend to use it to play/stream HD video to your TV, then HDMI seems currently to be the most universal interface for that task.rendu said:Hello, do you think this will be critical in future? If yes, why? I am between 2 laptops one with and one without. The one with is more expensive and I like it less so the only reason to get it would be the HDMI. Thanks!
