lack of reply buttons
why, when i navigate to the forums do i sometimes only have the "report abuse" button at the bottom of posts and no reply, quote etc?
is it to do with being logged on on two machines (home and work) and hence confusing the system?
logging out then back in fixes the problem
nads
when you cant see the reply etc. buttons you will see at the top of the topic a note asking you to login or register (in blue). Even if you are logged in in the red header.
seems to be a hicup in the system.
I had this. Solved by logging out and then logging back in again.
hth
