vaidyapaul:
I have been just following your story. A disgrace indeed
Why do you think I will not get much comment ( which so far, is true )?
I would like to buy the pioneer, but now I'm having second thoughts.
Is it only the 600M that's buzzing or also the other ones?
I doubt it would bode well for a magazine such as WHF to weigh in on this kind of issue - whilst WHF claim to be independent they do of course have to play ball with their advertisers and do rely on the manufacturers to provide them with material to review, hence I think it unlikely they will comment and can't blame them for it. Most of us old enough to remember will know why Jeremy Clarkson no longer gets to review Toyota's but then he's a guy who isn't afraid to speak his mind regardless of the consequences.
I have read several other reviews online however where reviewers have directly commented on the buzzing - and it seems to be an issue with the whole Kuro line past and present, not just the KRP-600M.
I'd like to clarify that in addition to IMHO an unreasonable large number of unhappy customers comments about this issue, I have also read many comments from people like JJ who are entirely happy with their set. Seems to be a luck of the draw issue. If you get a non-buzzer, I agree that this is likely the best screen you can buy, however, if you are one of the unlucky ones then it is a big problem.
For any others who have this problem, I experimented further this morning and found that using 'Drive Mode 2' can reduce the buzzing a lot but only for Pal50 TV signals - it does nothing at all for BluRay signals. Secondly, using the 'PowerSave Mode 2' setting will almost eliminate the buzz entirely but at the expense of picture brightness. I guess this may work for some and not others and does indicate to some degree that the buzzing has a large dependency on the type of material, refresh rates etc.
I'll let you know how this progresses.
