Kef2005.3 & Onkyo605 Settings
Has anyone else got this setup and can you advise whats the best settings and what settings should i have on the back of the sub i am new to all the and would like to know the best settings? Also when actually watching a film whats the best settings have the reciver on
regards
Then are no best settings that suits everyone. You can start by setting the speakers to 'small' and the crossover to 80hz in the amp. The crossover on the sub should be turned all the way round and then adjust the gain as necessary. Setting it at 12 o'clock is a good place to start but obviously is down to you.
As for the receiver settings, what you mean? Usually setting the amp to auto mode and letting the amp decode what is input is the best setting. I don't tend to use DSP settings much other than DPL Music and DTS: Neo6 for stereo TV broadcasts.
kPfRLewAJVEQ0AAAAASUVORK5CYII%3D
how do u change the speakers to small and what volume should the sub be on and the db switch
regards
