Kef R100 or Dynaudio Excite X12 for Rega Brio-R?
May not be too much help but heard the KEF R100s a lot with the Brio R as well as the LS50s but only the Dynaudio DM2/6s...
the R100s bar far were the better suited; fantastic sound, punchy/taut & deep bass with superb mids and top end. LS50s and the Dynaudios were very good but they didnt seem to gel as well with the Brio R but I think that's because they're not as a easy drive as the KEF R100s...
Hi Jazz21
About the Kef 100 i can not help you, but it was on my list to demo but in Portugal the dealer didn't have them...
Regardering the Dynaudios Excite X12 i don't get tierd to speak good things about my system combo Rega Brio R / Dynaudio Excite X12 !!!
it is important to know a bit more about your music tastes and the space you can provide to the Dyns.
In my oppinion:
- it is a killer system for detail
- very revealing
- a knock out for female voices, jazz, bossa nova, classic music, pop, rock ( Dire straits, Pink Floyd an so on...) the bass is fast, clean and tight. And for the speaker sise some time i get up to certify miself if the sub is off.
And if you like vinyl, oh my god, as i think the Brio R and the Dyns were made to play it!
if you need some more info plaese ask!
:cheers:
Thank you for your answers ... It seems that both have their strengths, I try to listen to both, but do not know if I will succeed (because long distance to the dealers).
Hi-FiOutlaw said:
I think that the Kef R100 aren't a match for the Excite X12, try instead the R300.
youve said you haven't heard the KEF R100s so how can you say they're not a match!
please only advise if you're in a position to do so; not here say or 'feelings'!
Kef R100 freq. Response +-3db 56hz - 28 Khz crossover freq 2.5 khz
sensit 86db
Kef R300 freq. Response +-3db 50Hz - 28 Khz crossover freq 500hz - 2.8 khz
sensit 88db
Dynaudio Excite X12 freq response +-3db 50Hz - 23 Khz crossover freq. 2,0 Khz
sensit 86 db
this is the paper talking !!! Not me!
You've probably already made your decision but I have just spent the afternoon having a demo of the sonos through the Rega Brio with the Dynaudio x12's and the combo sounds excellent. We tried various other speakers but there was no comparison. I have purchased the amp and ordered the x12's. I don't think you will be disappointed.
I'd go for the R100s as they are much easy to drive than the X12s. X12s require a bit more power.
That maybe very true, but it's also down to room acoustics, how loud the OP plays music - and as you rightly pointed out - the style of music the OP likes. As I've found out with my system, sometimes less is more.
Hi jjw20
Great CHOICE !!!
This Dyns X12 really are gems! And paird with the Rega Brio R that is a detaild and smooth sound they get along great.
Of course the Dyns X12 can handle and benefit from a more eficient amp.
But if you only have money for the Brio R, you'll have a great sounding system.
And if you want to take the best from them try with a turning table...
Best REGArds
currently listening to Sade - Diamond Life on vinyl through my Rega system........crikey it sounds so good!
have you thought about the RS1s???
I've got a brio r, rdac and rs1. I really wasn't taking to the rs1 as I found the LF boomy and boxy until I read somewhere to replace my qed silver xt cables with rega single quatro. Now they sound superb, especially for they're size and £220 2nd hand in mint condition 🙂
Do miss my MA RS6 though :cry:
I have not yet taken a decision ..
Currently, after a downgrade, I have a pair of Proac Response D15. Still not decided if I should change them ...
However, I see no one has yet to be heard both (X12 and R100) ...
Hi-FiOutlaw said:
Hi Jazz21
In my oppinion:
- very revealing
:cheers:
I leaning towards Excites. How they sounds at low volume?
jazz21 said:
Hi-FiOutlaw said:
Hi Jazz21
In my oppinion:
- very revealing
:cheers:
They soud amazing, my constant listenig volumes are at 3 o'clock, recently i've bought a RP3 TT and the over all presentation sounded much better then SBT/Rega DAC combo.
This weekend i've found that the filter 3 in Rega DAC has a bit more bass presentation.
The Dynaudios Excite X12 have a gorgeous timbre, the voice coil is something spetial!
If you buy them go easy on them for the first 50 hours, and the full burn in can take until the 100 hours mark.
:cheers:
:cheers:
