- Aug 10, 2019
- 2,556
- 4
- 0
What are the main differences between these two highly rated speakers in terms of a two channel setup?
jimm said:I found the kefs to be excellent for bass, the q100 is a great all round speaker, the only reason i changed to monitor audio rx1's was because i listen near field and found them a little shouty, i couldnt listen for long periods, i dont think you will be dissapointed with the q100's!
stevieg330 said:Hi Ryder2
Don't know if this helps or not but I was in the dealers a couple of weeks ago and had a listen to both the GX100 and GX200. They were connected to Audiolab hardware and to me sounded great. Very open and detailed. Not a hint of hardness / brightness though. Interestingly I didn't think that the GX200 was any more bassy than the GX100 despite the huge difference in size. In fact I preferred the smaller speaker.
I have a pair of RX6's which I think are excellent. They sound different to the GX speakers but as I use a completely different amplifier and the room is not ideal, it's hard to really compare them.
Fair to say that the GX speakers would definitely be on my shortlist if I were to upgrade.
HTH
Regards
Steve
