KEF iQ5se
just a quick daft question,got to foam bungs that came with kef's,i know where they go but what exactly do they do?
Foam bungs...if you feel that the bass response is so overbearing, they simply dampen down the bass. Personally I stay well away from them as I believe you should hear the speaker as it was designed to be heard but if for example someone has a rear ported speaker which they have to place near the wall, this can sometimes give rise to annoying boomy bass and so in that instance the foam bungs probably is the best thing to use.
ok thanks for the advise,i'll leave them out!! question,u got your ps3 hooked up to a external HDD? whats the reason for that? i guess it has to be fat32 right?
