Issue with 1910 Hdmi slot 1.
Hi all was well untill this week , i went to switch to my dvd player which is on the hdmi slot 1 and nothing , no picture no sound. ive checked that its not the dvd player and all i can think is that the hdmi slot one has died .
Anyone had the same issue ?
Any info would rock
aye , ive tried all my other hdmi input devices in that socket 1
Pindi
68
Do they work OK?
It could be your settings for the input, have you tried matching the settings that you've got for the other inputs?
I do remember someone on the forums having the same problem, it was a fault with the amp at the end.
None of the other devices work in that socket. Ive totaly deleted the profile and started fresh and no luck. :(
