is there a better turntable than this for the money?
Clare Newsome
1,657
If you want to be a DJ, buy a Technics deck. If you want the best performance for your budget, don't.
You could buy a very good Rega or Pro-ject turntable for £400 - is this your ideal budget, or below/above? Lots of people on here who'd be happy to help.
T
the record spot
Clare's pretty much hit the nail on the head. However, if you;re not averse to a spot of DIY, remove the arm, upgrade it to something along the lines of an RB300, stick on a better cartridge and you have a real winner of a deck (see link below).
If, however, you want something out of the box, on the shelf and with minimal fuss, go down the Rega route. The new P3-24 is apparently to die for.
http://www.tonearm.co.uk/dj-technics-arm.htm
tommyb
87
ok cool. Not sure why - I was always under the impression that direct drive was better than belt drive
Well, I'd be looking to spend around £250-£300 if I'm honest. So - Rega or Project???? that is the question isn't it?
I'll be matching with an Onkyo 875 (black), Quad L-ite 5.1 (cherrry) with Van Damme cabling. Probably be adding an NAD 542 cd player too (although might go for Marantz 6002 - really can't decide!)
In peoples experience - how should I spend the money - which Turntable?
Cheers guys and gals
gregory
45
i like regas others project but an extra £100 will get you the p3 with much more upgrade potential than a project.
