Is it worth it?
cheyworth
145
I have the opportunity to buy 2 NAD C270 power amps, for about £400 will I see an improvement in stereo over my T973 7 channel amp?
I can either Bridge the stereo amps or Bi-amp.
I can the Bi-amp my centre channel also.
To be used with TAG McLaren CD20R and MA silver 8i’s and matching 7.0 system.
Chris
hi mate im not familiar with your kit but if it helps i can tel you i have a NAD c352 to witch i added a c270 power amp the c352 sound great on its own the the c270 power amp made i big difference. not just to having more power but better timing stereo imaging and a much more musical sound i know this is probable not much use as im no expert and cant try your kit but by adding a power amp i gained a massive improvement..
one more thing ref last post i found using amp jumpers from russ andrews really helped to connect pre to power amp.
