Is it possible to remove Sky Channels?
DistortedVision
228
47
18,820
I bought a Pace Sky+ box for a bedroom. I stupidly bought a Freesat from Sky card For £20 thinking that it would give me more channels and remove all the channels which I do not have access to. It only gives you these channels: Five, Five USA, Five USA +1, Fiver, Fiver +1, LFC TV, Sky3, VIVA. complete waste of money since all of them apart from the last two (which I don't care about anyway) are available on Freeview.
Anyway, I was wondering if it is possible to remove all the channels I do not have access to?
Many thanks!
daveh75
Nope, the only channels you can remove from the Sky EPG are the adult channels.
Though what i did is set up a favourites list for the channels i watch.
To set-up favourites, press 'services' then 6 on the remote, then use the arrow/cursor keys to highlight the channels and press yellow to tick/select the channel,press select to save the list when you're done!
Then when viewing,it's just a case of pressing the blue button to scroll through the favourites list.
