is hitachi 42pd5200e hd ready ?
hi
i have the hitachi 42pd5200 which i bought before the hd ready badges came out, i want to buy the new toshiba hd ep35 dvd player which i would connect to the dvi input, my question is will it work, and if so what output resolution will i get ie; 720p/1080i my screen resolution is 1024x1024
any advice will be great, cheers, andy.
Andy Clough
776
Hi Andy
The Hitachi set is indeed HD-ready and will handle 1080i and 720p signals via the DVI input. Yes, it will work with the Toshiba HD-EP35, but the player will downscale 1080p video to fit the screen resolution.
hi andy
thank you for that that clears things up loads. i shall now put my order in for the new hd ep35 with confidence.
andy.
ps, sometimes on the tv skin tones look almost animated/oil painted have is there anything i can do to sort it out or is it the tv thats just not up to the job ?
andy.
