is chord rumour 2 good enough for my set up
i have my MA BR2 with my marantz pm6003 and linn lp12 and im using qed micro but ive ordered chord rumour 2 is this a better upgrade in cables. (the br2 are only until i save up enough for a better quality pair of speakers so no laughing) ha ha.
Gerrardasnails
295
19Hansen81:i have my MA BR2 with my marantz pm6003 and linn lp12 and im using qed micro but ive ordered chord rumour 2 is this a better upgrade in cables. (the br2 are only until i save up enough for a better quality pair of speakers so no laughing) ha ha.
Plenty good enough. It's a very good cable.
audioaffair
100
Yes, it is a very good cable - don't forget to get it properly terminated, ideally with Chord plugs and heatshrink
gregory
45
or save yourself some money and hear no difference and cut a couple of mm's off the ends.
Al ears
Moderator
Lets not start that old thorny issue again.
The OP wants to know about the quality of the cable not the nature of the termination.
I think its a good quality piece of wire and certainly adequate for any system.
gregory
45
what's wrong with saving some money, i never mentioned the cables quality but if an hi-fi retailer mentions spending money on termination that's all right is it.
Chord Rumour 2 is a great neutral cable...compared to that QED ***** it's amazing! Now whether ANY Marantz amp or MA speakers do justice to an LP12 is another thing.....
matthewpiano
232
18
18,795
I've always found it depends on the interconnects. Rumour 2 only really starts to work if you pair it with Chameleon Silver+ or something of similar quality. If you are using something more like Crimson interconnect then I'd suggest Carnival Silverscreen for the speakers.
sheehanjuk
28
having been present at the Chord demo at this years show in Bristol, in which they demo'd every cable id have to say id def plum for the Epic cable. the difference between rumour and carnival was minimal.
ASK THE COMMUNITY
