Is bi-amping the solution?
Brendj
Hi all
My current system consists of the following:
Arcam CD73
Rotel RA-03
Monitor Audio GR-10
I tend to listen at fairly high levels and the amp runs hot and then cuts out after 40mins or so. I've been offered a RB-03 at a good price and was wondering if bi-amping would solve this problem. Has anyone had experience with this Rotel issue?
Brendj
I only have £200 - £300 to throw at the problem. The RB-03 will be quite a bit less then that.
Thaiman
360
How long did you have an amp? and do you have this problem from start? I heard some complain about the Rotel is getting hot far too quickly. I can't answer your question about Bi-amp would sought out this problem, however, in gernal it will add control over your speakers (they are relatively easy to drive anyway)
I found this amp at a very low price and he will also take your Rotel in as a part exchange....the improvment in sound would be more than £500 worth!
The RA03 is integrated yes?
I'm guessing the RB is a power amp... is there not a corresponding pre-amp in the rotel line also? worth looking into IMHO...
ooh ooh! look what I found!
http://cgi.ebay.co.uk/Rotel-RC03-Pre-Amplifier-2-RB03-Power-Amplifiers_W0QQitemZ280149313885QQihZ018QQcategoryZ14973QQcmdZViewItem
Would be SWEET if it stays at 150 hehe;)
