iphone itunes to home theater
nads
with difficulty. play it from your PC and use your iPhone to control it.
but i think there is a new function in the latest OS that will let you stream to some other box which will then allow play back on the amp.
Andy Clough
776
Yes, if you have a new Apple TV (£99) you can connect that to your AV receiver, use it to stream iTunes from your iPhone and control playback through Apple AirPlay on the phone. Or you can use an Apple AirPort Express.
pwiles1968
153
PC/iTines to HiFi/AV is beeen discussed in another thread at the moment you may find some usefull info - http://community.whathifi.com/forums/t/542530.aspx
Mike_Schmidt:iam guessing a idock and aset of rca's but how do I change songs without getting off the couch? Thanks
You mean with with 2 babies on your knee - you need a remote my boy!
