iPad to rdac connection?
Rick1979
15
Can someone please tell me how I can hardwire the above? I have the camera connection kit but just get the message 'device not supported'. I'm aware of the rdac kw and rwand route but my rdac is the standard one. :wall: spent ages googling but end up with the rwand.
Thanks.
Just seen your question and I am trying to do the same. Did you find a solution?
Thanks!
It's all in the message! It isn't supported get onto Arcam support they will probably say they are not licensed for apple products via USB
Rick
I was curious enough to dig out my virtually unused Apple Camera Connection Kit & hook into my M-DAC. I opened the Music app, tapped on the Airplay icon on the top right & to my surprise "audiolab M-DAC" was listed. I'm listening to "Do you Dream in colour?" as I type. If I plug it into my iPhone4S, I do get the Unsupported Device meassage.
OK, this doesn't help you at all but thanks to this thread, I now know I have this option. I suspect the message you get means that there's no way around it, sorry to say.
