Evening All,
I've got a bit of a dilemma at the moment. I'm pretty much set on a Denon 2311 receiver for my forthcoming B&W 684 Theatre set (684 Fronts, 685 Reads, ASW601 and a HTM62) and was somewhat dissapointed to read that it has no network connection (3311 and up only). Which means, no native DLNA and no internet radio..... :-(
I can access most of my video content via DLNA on my Samsung C8000, and I guess i'll get audio back to the receiver via ARC for surround. So that should be covered.
However on the music/hi-fi side of things I have some question, which brings me back to the reason for this post.
I could survive with USB playback for a while, however i'm not sure on whether the USB playback supports FLAC? I don't see a mention of it in the manual......
I guess if it doesn't then i'm left looking for a streamer to pull it from my PC. Now interestingly enough when looking at the Denon site it does state that with the ASD-51N you gain DLNA Internet radion and FLAC support, but it's still music formats only by the looks of it.
I'm just wondering if buying the ASD-51N is worth it to gain integration with the existing denon menu's or -
- whether I should get a Touch (which seems to have a good DAC) to cover off the hi-fi side including internet radio.
- take a look at a streamer for video too e.g. a WD HS, however the quality of the audio (DAC and bitrate - for example I've read that the WD downsamples everything to 44.1) has me a bit uncertain.
- consider the move up to the 3311, but is it worth the difference in price?
I'd appreciate hearing now others have tackled this.
Thanks in advance.
Phil.
Thanks in advance.
Phil.
