- Aug 10, 2019
- 2,556
- 5
- 0
I listen to music usually from my phone(with a 3.5 mm jack and mini usb) or my laptop. I want a good pair of active speakers preferably with a usb port and a built in DAC. I like the audioengine a5 but im not sure if it has built in dac since it doesnt support music feed from its usb port its only for charging:-(((
B&W MM 1 solves this problem but is "expensive" and has only 18 watts per channel of amplification as opposed to 50 watts per channel in A5's.
Also the larger question is of a DAC. Most of the reviews i read say that the dac chip on board the ipods & laptops is crappy at best.
However at this budget (200-250 pounds) does a DAC make a difference to the sound? Is it discernible? Is it worth the premium or is it better to stick to 3.5mm jack.
