Incorrect link for latest digital issue
Retne
48
Hi there
Just clicked on the "buy latest" link from here: http://www.whathifi.com/digital-magazine
and got
http://gb.zinio.com/browse/issues/index.jsp?skuId=416171242&rf=sch&sch=true
which is the July SKU. It should be 416186148, looking at the October back issue link.
Or even http://gb.zinio.com/browse/publications/index.jsp?sch=true&productId=500626440 which appears to link to the mag's home page on Zinio.
Anyway, now to go back and click buy, a bit belatedily (still trying to figure out if I should rush down to Richer Sounds today to buy an amp...)
R
Hi Retne, yes, can see your problem there. It appears the main digital subscription page has been updated, but not the single issue page. However, if you scroll down below the main cover under 'Back Issues' you'll see the October 2011 issue there, just click on that, add to your cart and away you go.
Cheers both.
I had got past that one and had bought the correct issue, and finally had a chance to glance at it (busy day, and still trying to decide if I should rush down to Richer Sounds to buy the Onkyo NR609 today)
Kinda regretting it though. The quality of writing itself is still wonderful, but the app is fairly limited. On my Android I can't seem to go back, the zoom for landscape mode is frustrating (I can't zoom as much as the less useful portrait mode) and a bunch of other UI issues. Is it worth putting feedback here, or will they get lost somewhat, as Zinio isn't just servicing you?
R
Given that the problems are with the Zinio Android implmentation, rather than with the magazine file itself, probably best if you pass on your feedback to Zinio directly, using the response form here
Thanks Andrew. I must point out that my post was all positive for the magazine itself, and I realise Zinio will be making their app all-improved as time goes by.
I may just see if I can add to the voices on what priorities I personally would like to see. Just dipping my toe in the world of digital magazines. Hopefully it will hurt less than my actual toe, which I broke.
Anyway, I'm off now to download another app... I made a mad dash to buy that Onkyo 609 amp...
Keep up the good work 🙂
Rob aka Retne
