- Aug 10, 2019
- 2,556
- 5
- 0
I have a pair of old wharfedale dovedale SP's. Thats the ones with the double 6.5" mid bass drivers as appose to the single larger driver. Anyway, i have replaced the tweeters with "ScanSpeak D2905/950000 8ohm" and the bass drivers with "H1215-08 CA18RNX 8ohm". The midranges are origonal as i was able to re-centre the cones.
Now my question is, how can i find out the origonal impedence of the old speakers, so that i can make sure i have chosen the correct drivers to replace the old ones. When i measured the DC resistance accross the old wharfedale Mid/bass drivers i got a reading of 12ohms, and the tweeters measured 4 & 5 ohms. The midranges measured 6ohms.
I assume that the midbass drivers would therefore likely be of 16ohm impedence, and the midranges to be 8ohm impedence. However i am unsure as to what the origonal tweeters would be. Can anyone suggest what impedence the tweeters would likely have been, also, seen as though i have 4x 8ohm H1215-08 CA18RNX speakers how would i go about adjusting the wireing so that i can as closely replicate the old 16ohm impedence that existed on the origonal speakers. FYI, the 2 mid/bass are wired to the crossover in a parallel connection therefore reducing the total resistance/impedence by half that of a single speaker.
Sorry for such a long winded post, but i have been trying to work out these issues for some time, and i didnt know what else to do other than post them all at once here.
Thanks in advance to any suggestions.
