- Aug 10, 2019
- 2,556
- 5
- 0
Hi ,
Im starting all over again ive been away from home cinema etc for a number of years so im starting from scratch. Ive started just with a dvd and tv ... Sony Hxd 995 and my new Tv should be here shortly .... Sony KDL-46z4500 which i know should go well together (or hope) . I have a PS3 which will do my Blue ray for now. So my questions are a couple
Best way to connect to TV ?
What would make a good AV receiver ? Ive had a look at the Yamaha DSPAX863SE any thoughts or other suggestions ?
What would be the best interconnects for these .... do i need to make any set up adjustments ?
And finally speakers for Music & Speakers for Cinema ?
Any type of help would be greatly appreciated as to be honest the upscaling terms etc have me a bit baffled so i wont be insulted if you start with basics.
Buying its one thing setting it up to get the most is another .
Thanks ,
Thanks ,
