rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
CnoEvil said:rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
Not sure about that. The 35i has crystal pure clarity, bass slam that would put Thor's hammer to shame and is as fast as a Whippet on Speed. *dirol* (shame it's been discontinued *sad*).
TrevC said:CnoEvil said:rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
Now now boys, no point in arguing over imagined characteristics. :O)
CnoEvil said:TrevC said:CnoEvil said:rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
To know that for sure, you need to have heard one.
TrevC said:CnoEvil said:TrevC said:CnoEvil said:rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
Nope. Only the ability to recognise meaningless waffle is required. The speed of an amplifier indeed. What twaddle.
CnoEvil said:TrevC said:CnoEvil said:TrevC said:CnoEvil said:rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
It's down to transient response and damping factor.
http://www.audioholics.com/audio-amplifier/amplifier-slew-rate
TrevC said:CnoEvil said:TrevC said:CnoEvil said:TrevC said:CnoEvil said:rainsoothe said:Also, I don't think class A sounds good with everything - it certainly suits jazz and classical, but if you throw rock, progressive rock at it and some others, like drum and base, hip-hop etc, I think you won't get what you're looking for.
So a valve amplifier that isn't good at high frequencies and has a low damping factor must sound terribly slow to you.
TrevC said:So a valve amplifier that isn't good at high frequencies and has a low damping factor must sound terribly slow to you.
CnoEvil said:TrevC said:So a valve amplifier that isn't good at high frequencies and has a low damping factor must sound terribly slow to you.
A badly designed Valve amp can sound slow, dark and bloated, wheras a well designed one will sound great....they live or die by their power supplies.
TrevC said:CnoEvil said:TrevC said:So a valve amplifier that isn't good at high frequencies and has a low damping factor must sound terribly slow to you.
You see, that's where you and I differ. If I know nothing about a subject I don't mention it. You just keep waffling on, making stuff up.
CnoEvil said:TrevC said:CnoEvil said:TrevC said:So a valve amplifier that isn't good at high frequencies and has a low damping factor must sound terribly slow to you.
The difference between you and I, is much more fundamental and deeper than that.
TrevC said:Deep and meaningless once again.
TrevC said:CnoEvil said:TrevC said:Deep and meaningless once again.
Go on Trev, leave TrollC in his box for once and try posting something positive, polite and approving....I dare you.
You might explode, but it'll be worth it, just for the shock value.
I'm always polite, except for the times my meter hits the end stops. You trigger it repeatedly.
CnoEvil said:TrevC said:CnoEvil said:TrevC said:Deep and meaningless once again.
I'll take the bomb squad off standby.
As you were.
