IEM + Headphones (Amp) + speaker(s) for livingroom 1000-2000e
TommPar
As the title says, I am looking for IEM's for portable use, headphones for listening at home
and also speakers or an All in one like the Genova L for my livingroom. Budget 2k euro max, preferably
closer to 1k.
For IEM's I'd be looking at lower end ones (max 200e) because I tend to always lose/break my iems' s.
For headphones, does not matter whether open or closed. Max 1000e with an amp if needed.
For livingroom ive been mostly looking at all in ones, since the speakers need to be portable
enought that I can fit them in a larger luggage bag when moving ( also pref under 20kg)
As connection options I would prefer bluetooth (aptX) and 3.5mm. Also open for suggestions
but only active speakers. And budget, what ever is left after iem's and headphones/amp.
the individual budgets for each item can differ as long as the total budget stays under 2k euros.
and also I live in the nordics at the moment so if you link items then would appreciate if the store is in/ships
here.
As for sound, I listen mostly bass heavy music so good bass response would be preciated.
