I tunes question.
nads
1,116
443
19,570
if it has put an album in the compilations folder and you move it out to where it should be.
EG:
A Camp by A Camp
which was thier first album. so i move it in window to my A Camp folder but it get moved back? i thnk i know when it happens.
ok also had a clear up of unwanted files and i get a grey ! by the name. is there an easy way to update/remove the dead links?
Sorry for the Qu´s but the English used is interesting.
Highlight all tracks within the album, in iTunes...
Right click
Get info
Uncheck "part of compilation".
iTunes will move the files to a new folder providing the "manage my library" box is checked.
nads:ok also had a clear up of unwanted files and i get a grey ! by the name. is there an easy way to update/remove the dead links?
This is a pain, yes - are you on Mac or Win, I forget?
