True Blue
185
Went into my listening room tonight and could hear "something". Put my ears to the speakers, a definate hum from both.
Then put my ear next to my new hicap and it too is humming.................
Switched all off tonight, will make and break all connectors / tidy up cabling tomorrow.
Any other ideas??
True Blue
185
Right quick update, this one has freaked me out seeing as I have a dedicated radial cct to the HIFI.
When I switched off my Subwoofer (seperate room, seperate cct), the hum in the speakers went away..............................................????????????????????????????????????????????????????
However the HI CAP has still got a transformer lamination hum, which is very low level and expected.
Still unplug and replug all connections (and dust) tomorrow.
TheHomeCinemaCentre
70
It could be humming becuase it doesn't know the words.........Sorry couldn't resist
True Blue
185
All sorted.
Removed ALL my AV equipment plug cases and checked all earth connections.........loose couple found.
Stripped down the HIFI, dusted, cleaned, checked tightness on all electrical plug connections, reassembled in a slightly different configuration, the hicap is no longer on the floor next to my NAPSC, it has its own shelf now. A bit of cable dressing, the use of some cable ties and
Et voila!! All powered on and not a sound, perfect.
Now time to chill and listen to music
