[quote user="Justin1970"]
Hi there,
I have noticed an audiable hum from my Arcam P90 power amplifier when I get very close to it (standing with my ear at the same level), but I do not hear any noise from my Arcam A80 integrated. The hum is from the amplifier and not from the speakers. Is this normal ?
Cheers, Justin.
[/quote]
When you stick a large amount of magnetic (Iron core) material in a powerful (transformer coil generated) magnetic field, one might expect a little movement
. As Andrew says, sounds like a bolt needs tightening.. a Lot of amplifiers have the bolt coming out the bottom of the case as toroidal (doughnut shaped) transformers are usually mounted by a plate that sits on top, covering the central hole and gripping the unit, with a big bolt that goes through to mount it on the bottom side of the case wall. As you tighten in you pull down on the plate which pulls the transformer body harder to the case wall (which will often have a kind of 'seat' for the transformer to rest in, rather than pushing right into the bare metal).
The short story is, if this bolt comes loose then the transformer is free to vibrate. Not a problem in itself but you just
know it's gonna get on your nerves. Co-incidently. Some time ago I built my own amplifier which used a small toroid to power a 25w stereo integrated amp. In order to test the power supply load I stuck some resistors (not speakers) into the speaker terminals and whacked the volume up full. I was astonished that even though there were no speakers connected I could still hear the music... from the transformer..
