hsssss sounds
Cypher
156
I have this system ;
Rotel RA-04
Marantz SA-7001
Monitor Audio BR2
Chord cables
This system sounds amazing for the money but the only thing I don't like is the exagerrating of the 'S' and
'T' sounds. When I play Sting - Brand New Day and some other CD's the vocals are sometimes producing
too much 'hisssss' sounds if you know what I mean.
Is there a solution to this (small) problem ?
Andrew Everard
1,878
Not a need for more running-in then, which leaves me at a bit of a loss. There are some recordings which are more sibilant than others, either due to miking or vocal techniques - Freddie used to sound like a pit of snakes on some Queen albums! - and the Sting discs do tend to be pretty bright, so it may just be recording-dependent.
There's nothing in your system especially prone to over-brightness, and nothing much immediately changeable to give a sound that plays this down without complete changing the sound into lush blandness. Might we suggest a little left hand down a bit on the treble when playing problem discssssssss?
