kazuhito said:Lets talk about common priority ways on upgrading Rega RP6 :bounce:
stevebrock said:kazuhito said:Lets talk about common priority ways on upgrading Rega RP6 :bounce:
No mention of amp PP
plastic penguin said:stevebrock said:kazuhito said:Lets talk about common priority ways on upgrading Rega RP6 :bounce:
Yeees http://www.whathifi.com/forum/hi-fi/best-amp-for-my-proacs-rega-brio-r-vs-naim-nait-5si-vs-sugden-a21a#comment-2941511
You've replied to it.
stevebrock said:plastic penguin said:stevebrock said:kazuhito said:Lets talk about common priority ways on upgrading Rega RP6 :bounce:
yes after you mentioned it
kazuhito said:Thanks ALL and I'm sorry for your confusion. But I would like to talk about JUST ways of upgrading Rega RP6... :clap:
I'v had upgraded with Rega white belt. However I feel that the white belt is not a massive difference over the black Belt. :roll:
kazuhito said:. . . JUST ways of upgrading Rega RP6... :clap:
kazuhito said:What's wrong with Rega Fono MM MK2?Rega Fono MM MK2 is winner 2013!? :?
CJSF said:kazuhito said:What's wrong with Rega Fono MM MK2?Rega Fono MM MK2 is winner 2013!? :?
Very Simple, kazuhito . . .
Quote: "Best phono stage, Awards 2013. A great all-rounder that will deliver sonic excitement to any budget set-up".
Steve is pointing you in the right direction. Presuming you want to move to the next level?
CJSF
plastic penguin said:CJSF said:kazuhito said:What's wrong with Rega Fono MM MK2?Rega Fono MM MK2 is winner 2013!? :?
CJSF
But if he's looking at Sugden and Naim amps, they ain't budget.
CJSF said:plastic penguin said:CJSF said:kazuhito said:What's wrong with Rega Fono MM MK2?Rega Fono MM MK2 is winner 2013!? :?
CJSF
That is the point exactly PP, an RP6 is not a budget TT, the OP seems to be looking to 'move on', therefor the Rega Phono stage will be out classed, especially if a cartridge change is on the cards, so the up grades are necessary . . . ?
CJSF
plastic penguin said:CJSF said:plastic penguin said:CJSF said:kazuhito said:What's wrong with Rega Fono MM MK2?Rega Fono MM MK2 is winner 2013!? :?
CJSF
Then what's point in putting this: I just don't get why one moment you state that the Fono is a great all-rounder when you know he's moving on? Anyway, that's all irrelevant as he's decided to go for an amp with a built-in phono stage, I think - that could change any minute now.
kazuhito said:Thanks ALL,
At first I need a good integrated amp for my proacs.
Next, if I am able to choice a built-in phono stage with the good amp, I want know whether the a built-in phono stage is better than Rega FONO MM.
Please, let me know how are Sugden A21a2 and its built-in phono stage?
