I have a run of a bunch of cables - visible section is about 4m - and they look messy. I think the bunch is about 3.5-4cm in diameter.
I have seen so far:
- plastic mesh sleeves (often used on display at Loewe shops) - but how do you thread so many cables through its entire length?...
- sort of spiral-cut or spinal-cord-like-cut plastic pipe (Maplin?) - solves the threading problem but does not look as tidy...
What products are availble to tidy this up? Any DIY solutions that you know?
would apreciate advice
I have seen so far:
