how to set up plasma tv
hi my dad has a toshiba 42 inch plasma tv (not hd ) well he his having another plasma but hd so he will be giving me his old plasma model no toshiba 42wp27 rebadged panasonic pwd5 his old plasma is connected through his yamaha amp and sky box as the plasma does not have speakers or tv tuner built in what would i need to set this up in my own house ? i would be using freeview box and a recordable dvd player but i have no amp at the moment but i have a denon rcd-m33 hifi would i need another amp to get sound out of tv ?.if i need a amp what sort would i need and what connectors to get it all working sox for all the ? but i'm ok setting up normal tv dvd etc but if i have to go through a amp hav'nt got the foggest thanks for any replies
This Plasma has various inputs (I have the same set but the Panasonic one in my bed room) that can easily be used and it also has terminals for speakers if you wish to use them. I have a freeview box pluged into the PC input via a Scart to PC cable which I got from Keene Electronics, and my DVD player conected via Component. There are inputs for sound on all if you so choose to use them. Considering the age of the screen the results are still very good considering its only a 640x480 panel with a good black leval to boot. This screen was a award winner in it day dont forget.
thanks for info could you please send me link for the scart to pc cable and component to scart to make sure i get the right ones as i could not find it on keene electronics thanks
http://www.keene.co.uk/electronics/product.php?mycat=32_119_547_642 You will also find Scart to Component here as well. They are quite expensive but well worth the price.
would these 2 do the trick ?
http://www.keene.co.uk/electronic/keene-electronics/scart-to-3-phono-plugs-rgb-or-component-1m/SBB71.html
http://www.keene.co.uk/electronic/keene-electronics/scart-to-15-pin-hd-plug-h-and-v-sync-1m/SBB91H.html
Not sure I would give them a call and they will be able to tell you. The more expensive version that I have comes with its own power adaptor to boost the signal and stop any sync issues and I'm not sure about the cheaper version if you get any sync issues or if it is wired for RGB.
