How to get the best of my SEN HD 650 Headphones? Budget Limited at 400GBP.
knowing that I have my music in WAV format on my computer.
I was considering a DAC (i.e. DACMAGIC) & a headphones amplifier .
All suggestions are Welcomed.
i also have the 650s brill headphones, why not try ebay for musical fidelity x-can v3 or v8 headphone amps and add the cambridge dacmagic
a very good sounding set up and you can further upgrade the headphone amp by changing the valves for some russian millitary spec ones..
is connecting the DACMAGIC to Graham Slee NOVO dicrete amplifer a good idea?
Thanks for the advice,
but I was wondering if combining a DACMAGIC to Graham Slee Novo amp would do a good Job?
