How to get best out of my Blu Ray?
I have just bought a Panasonic BD50 Blu Ray player.  The problem being, the player has Dolby True HD Decoding yet my amp does not have HDMI inputs.  Now, I cannot afford to upgrade my amp to accommodate for this, but I want to make sure that I get the best sound possible.  I currently have the Blu Ray connected via Coax, is there a better way that I can get the optimal performance or have I got it set up the best way possible?  PLEASE HELP!
Sorry, forgot to mention is was a Denon 1907 amp, hope this helps.
devo18uk:Sorry, forgot to mention is was a Denon 1907 amp, hope this helps.
Get three pairs of stereo interconnects and connect the multi channel out on the BD player to your receiver. You will get HD audio this way.
http://community.whathifi.com/forums/t/245167.aspx was it not answered here?
you are certainly trying all the fora for an answer allready given http://community.whathifi.com/forums/t/245774.aspx
Sorry I didn't quite understand the last answer, I needed it in simpler terms. ÿI'm a bit of a dumbass
Sorry, I didn't quite understand the other answer, I'm not the brightest 😉
ÿ
No worries, if you don't know the terminology, it can all be a bit baffling. In case you're not sure, basically the BD50 has 6 multi-channel outputs on the back which I think are on the far right of the player and are labelled Audio Out and then each one will be labelled for each speaker i.e. Front Left, Front Right, Center, Rear Left, Rear Right and Subwoofer. You should also have corresponding inputs on your Denon amp so you merely hook these up as Gerrard says with 6 standard RCA phono leads.
You can then set the Blu-Ray player to decode onboard and output the sound over the multichannel outputs and set your amp to the multi-channel input and you should then get HD audio. This is because the standard optical and coaxial outputs aren't able to send the full HD audio soundtracks out as there isn't enough bandwidth. However, by setting it to decode onboard and export via analogue, you can get this.
Let us know if you need any further help.
EDIT - looking at a pic of the back of the Denon 1907, it looks like the multichannel inputs are on the bottom left, labelled EXT. IN and then corresponding letter(s) for each speaker. The Denon actually has 8 inputs (for 7.1 signals) so you don't need the SBR and SBL inputs which are for the surround back speakers present in a 7.1 system. Since the Panasonic only has 5.1 output, you can't use these, but that doesn't really matter since there are very few native 7.1 soundtracks anyway.
Thanks very much for all of your help, just got the task now of getting some Phono leads now, which by the looks of it are gonna set me back a few quid. ÿOh well, here it goes.
Nice to follow this discussion. Prof hat, are you saying that we will get exactly the same sound quality (true HD quality) by doing this?
professorhat:
Right then, this could take a while.
I've got my Phono leads and got them all hooked up FR/FR, FL/FL etc but now comes the difficult bit of setting it up.
I've got the following 4 options when it comes to the sound setup on the blu ray:
Dynamic Range Compression - On, off or Auto
Digital Audio output - This has a sub menu which consists of Priority setting which is either Secondary Audio, Audio Quality or User
PCM Down Conversion - On or Off
Downmix - Stereo or surround encoded
Where do I go from here?
And I can't even begin to find out where to change the Amp to play the Analogue input.ÿ
Just found the Connection menu and this has given me the following options for speaker setup:
Multi-Channel or 2-channel. ÿWhen I go into the Multi-Channel Setup it lets me adjust what speakers I have, delay in ms and change the db for each speaker, then test it and complete. Is this where I need to be or am I barking up the wrong tree here?ÿ
devo18uk:professorhat:
On your receiver (and I'm going by the 1908 here as I can't find the 1907 manual) you need to change the input mode to EXT IN.
On the Pana settings. You need the Speaker to show Multi Channel and the hdmi audio output needs to be set to OFF.
Your other audio options should be set to Auto for Dynamic Range, Digital Audio - OFF. PCM Down Conversion - OFF and Downmix - Surround.
devo18uk:
No, that's what you want.
The digital audio output doesn't have an 'off' option, it just lets you set the priority setting to secondary audio, audio quality or user preference?
devo18uk:
Try user preference then.
kweq:Nice to follow this discussion. Prof hat, are you saying that we will get exactly the same sound quality (true HD quality) by doing this?
I can't say it will be exactly the same since it's using the DAC onboard the Blu-Ray player rather than the one in the amp, but you will certainly be getting the HD audio soundtrack.
