Hi all,
Can someone please explain how to add a subwoofer to Temple Audio Bantam Gold.
Thank you.
Thank you.
The_Lhc said:You'd need a sub with high-level inputs that you'd wire to the speaker terminals, either on the amp or on the speakers themselves if more convenient.
k77stan said:The_Lhc said:You'd need a sub with high-level inputs that you'd wire to the speaker terminals, either on the amp or on the speakers themselves if more convenient.
that way the sub blends nicely as it gets he same signal as your speakers,i have mine just like that and the thing i like is that every time you put the volume up or down,the sub goes along..
