How easy is it?
landzw
281
Ok tech has moved on from the days of video recorders , but i'm in need of some UFC of ESPN but i will need to be able to record the UFC events and watch in my own time
The only current way i will be able to watch ESPN is using a CAM in the back of my TV , The question is can i use my foxsat HDR to record from the TV?
If not any suggestions on how i could do this as i've seen cheap top up tv boxes with pvr for cheap enough prices though i just din't want more boxes under the tv
I take it one of the panasonic freeview+ with HDD and DVD recorder can record straight from the tv but can it do the signal from the CAM ?
Any advice would be appreciated
landzw:
The only current way i will be able to watch ESPN is using a CAM in the back of my TV , The question is can i use my foxsat HDR to record from the TV? No, PVRs can't record from external sources-Only their internal tuners.
If not any suggestions on how i could do this as i've seen cheap top up tv boxes with pvr for cheap enough prices though i din't want more boxes under the tvA cheap TUTV PVR is probably the best solution ,tbh.
I take it one of the panasonic freeview+ with HDD and DVD recorder can record straight from the tv but can it do the signal from the CAM ?Provided your TV has a scart output.Though to be able to record,it would require A) the TV to be switched on and B) tuned to the channel you wan't to record.
