A admin_exported New member Aug 10, 2019 2,556 5 0 Aug 31, 2009 #1 Can anyone help with the above or provide a link for info?
nads Well-known member Nov 29, 2007 1,146 463 19,570 Aug 31, 2009 #2 you need a logitec remote and a certain accont to log into. the info can be found on another AV site. try google.
K kena Well-known member May 28, 2008 104 0 18,590 Aug 31, 2009 #3 A Philips Pronto or a One For All Kameleon will also do the job for you.
A Anonymous Guest Aug 31, 2009 #4 Thanks guys. I've already got a Logitec Harmony 555. Presume this will work with the log in details etc.
bigboss Moderator Mar 25, 2009 6,443 1,386 27,570 Aug 31, 2009 #5 Search 'Panasonic multiregion remote' on ebay. You'll get a remote for £11.99 which is the easiest to multiregion your player. I'll send you the link tomorrow (can't access ebay from here) if you still have trouble finding it.
bigboss Moderator Mar 25, 2009 6,443 1,386 27,570 Aug 31, 2009 #6 http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=110373360326 Check other items from this seller. He sells Panasonic remote as well. Got the link from one of my previous posts.
A Anonymous Guest Aug 31, 2009 #7 hey i have a remote i bought of e bay for £15 which i used to unlock my bd30. it has 4 goes left on it and was dead easy to do if it will do your bd35 (ill have a look in a bit) you can have it for £6 delivered if ur interested. andy
