How do i connect up my system ?
Hi , i am a bit of a home cinema novice . Tomorrow i will be taking delivery of a samsung 6 series 40" LCD and a Humax Foxsat HDR .
This is all my equipment that i want to connect up :
Mordaunt short alumini 3 lcr centre speaker
Mordaunt short alumini 9 sub
cambridge audio azure av reciever ( BTW i have already connected the speakers to the reciever)
PS3
Samsung LCD
Humax freesat HDR
So if somebody would tell me how i would go around connecting it all up and inform me on which cables i need that would be much appreciated :D
Chev :D
Easiest method I can see if
HDMI from PS3 to 340R
HDMI from Freesat to 340R
HDMI from 340R to TV.
Looking at the manual I don't think the 340R decodes auido from HDMI in which case you will need either an optical or co-axial cable from both PS3 and freesat to the 340R as well.
You will then to assign these in the 340 R settings.
Hope this helps.
Also, Are you only using a centre channel and a sub? No other speaker?
okay thanks alot :D
ermmm yeah for now , im sure i will invest in some more speakers in the future.
chev
Update, The PS3 can not use a co-axial cable, and I think the freesat doesn't either.
Use optical cables on both to be sure you are getting the correct sound.
cool :D ive had a quick look at the inputs on the amp and i couldnt see where the optical audio cables would go in ?
chev
At the top about half way along, there is a section labeled Digital Optical in, these are the connections you need and are small squares connections that don't protrude from the casing like most of the others.
okay nice one :D i am officially sorted knowledge-wise , thanks alot Dock :D
chev
daveh75
You're going to need front left and right speaker's for your set-up to work properly.The centre channel is mainly for dialogue and also centre effects etc. without front l+r speakers your gonna missing a big part of the sounds.
Your welcome Chev,
Daveh75 is right though, without support from at least left and right speakers you might find the sub sounding a bit strange and a lot of the sounds missing.
